Hi all i am not getting a way to group the records in a grid of forms on the basis of a two fields used on form grid in AX 2012
I have 3 data sources in my BOL form, WMSOrderTrans,SalesLine and InventDim and the BOL form is a child form of WMSShopment form.
Now the situation is i am getting all the required field on the grid after applying the joins on data sources but now i want to group the retrieved records and sum up the real type fields which i am unable to achieve …
I also tried same with AOT query object but when i add a group by field then no other data will be retrieved on form except that group by field data.
Please suggest the solution if u have , it will be really helpfull
