Group Planned Purchase Orders
Hi there,
Those that are using Master Planning probably are familiar with the Split functionality that is available on the Planned Purchase Orders form. This feature enables one P.P.O. to be spited in two, and the quantity and requested date when splitting is entered for the newly created P.P.O.
What I need is a feature that will enable reversing of this operation. To select the two P.P.O.'s and group them into one.
Does anyone know if this feature exists as standard functionality or needs to be developed?
Thanks in advance!
Kostadin
hi,
there’s a reqtranspomarksumup menuitem which calls a class with the same name.
this option shoud be in the same buttonfunction that shows the split functionality.
regards
Somebody by accident switched the visibility of that menu item to No :slight_smile:
Thank you very much!
