Hi. I have to add a button control for each sales line (forms 42,46). There is a way to add a button into each line?
You can’t add a button control to a table box.
However,
You have the trigger “OnAssisEdit” to write code (the button will appear when there is at least one line of code) … . the OnLookUp, and OnDrillDown work quite the same way … .
You also can add a checkbox and work with a bitmaplist and the OnPush-trigger…
