Grid record deletion problem
we develpoed a
custom form,
custom tables and
form is attached with a grids and it has a master/detail relation
Our problem is
when we want to delete a record from the grid
it is not deleting the current record but
it always deteles the first or last record
Our requirement is
to delete the current record on
which the cursor is pointing out
please replay urgent…
thanks
For me this situation sounds very strange. Can you let us know some more details like: 1. do you have any custom code in the datasource’s methods as validateDelete(), delete(), active(); 2. from which datasource are you trying to delete - the master or the detail. 3. Did you checked that the datasources are joined correctly.
