grid database
hello,
i have a grid that contains 2 fields,the first one RealEdit1: contains datafield: ItemId from database InventSum, i want to show datacolumn : PhysicalInvent from the same database on the second field: RealEdit2 which correspond to the ItemId.
thank you in advance.
Hi Khadija,
It looks like you’re asking about coding in Dynamics AX? If that’s the case, you’ll probably get a better response if you post your question in that forum.
Moved from NAV Developers forum to AX developer forum.
And what’s the problem? How to sum PhysicalInvent across inventory dimensions?
