Grid Combo box enter ax2009
Hi friends
Pls help
I have table empl inside table
Anum int number empl
Name string name empl
form è Gridè field(Combo box)
form è Gridè field(StringEdit)
from Combo box when I dropdown and click number I need to show the name in field(StringEdit)
what I need
1- Write to Function to get the name
2- Where I but this function in which method and where (table- Combo box)
hai bas:
please explain in detail and clearly…
when u say u need the name… but from where ?
Hi Bas,
It is not clear…can you explain it…
Naresh Kolli
in table empl have 2 field (empl_no ,name )
(1,2,3 …) empl_no
(bas , Naresh Kumar Kolli , Shon Davis) name
in the Grid have to Columns
empl_no when i dropdown data
(1,2,3 …) when i click show me data in the name Colum name (bas , Naresh Kumar Kolli , Shon Davis)
i hope It is clear
i hope it clear
ihave table this table EMPL_TABLE have 2 field (EMPL_NO, EMPL_NAME)
icreate form this form have Grid and this Grid have 2 columns first colum combo box have EMPL_NO from EMPL_TABLE
now what ineed when dropdown and click number I need to show the EMPL_NAME from EMPL_TABLE in sec2 colum after chose the number from combo box show the name sec2 colum NAME automaitic no need to write in the name field
[H][H][H]
HI bas,
write the code in Modified method.
Tb.name = TableName::find(DSName.EmpNO).Name;
HI Bas,
FOrm->DS->Fields->emplid->modified() Method
EmpleTable empl;
select firstOnly empl where empl.emplNO == EmplTable.EmplNo;
EmplTable.name = empl.name;
thanks it works
