All, I will need your help in finding the answers to the following: 1) What is the graphical reporting engine in Axapta? 2) How do you generate graphs with full Excel function (points and lines, log axes, two axes,pivot etc.) 3) How much programming is required to generate graphical reports? Are there tools to assist? 4) Is there a reporting portal, like the Crystal Enterprise? Where is it? How does one use it? 6) Can graphical reports be scheduled and sent via e-mail with a URL link? (either inside the user portal or another web server). Thank you for your help and please let me know if further clarification is needed. Alin
Hi Alin, Have you had a look at OLAP integration yet? You should be able to download a technical document on OLAP integration from Technet website. This solution has the answer to all your queries. Regards, Harish Mohanbabu
