Hi I have recently generated an excel sheet through AX code.
Now, I have to generate a graph on the same sheet through AX code.
If you use Excel Interop, get collection of chart objects for the worksheet and add a new chart - C# code would look somehow like this:
Worksheets("sheet1").ChartObjects.Add(100, 30, 400, 250)
You can find details about Chart’s members in documentation. This example could help you too.
Thanks Martin for the reply.I will get back to you after trying the same.
