Grand Totals
Hello
How to write an aggregate function with the aggregate function.
Sum( a* sum(n)) .
I need total of a* Sum(n).
Please help.
Barathy
do you want to find a total of a field and multiply with other constant ?
you mentioned sum(a*sum(n))
a & n are table fields ?
or a is constant?
a & n are table fields.
a - unitcost
n- remaining qty
inventory = Unitcost * Sum(remainingqty)
I need the total inventory,
lets declare Record variable(RV),and a decimal Variable (DV)
Step1:To get sum(Remaining qty)
RV.RESET;
if RV.FINDFIRST then begin
repeat
DV:= DV + RV.
until rv.next = 0;
end;
DV have the total remaining qty
now multiply with unit cost so
declare Decimal variabl DV1
DV1 := unitcost * DV
Now find the total of DV1(Inventory):
declare record variable RV1
RV1.RESET;
if RV1.FINDFIRST then begin
repeat
DV1:= DV1 + RV1.
until rv1.next = 0;
end;
Waiting for your reply
Jerome Marshal.J
