An error occurred during local report processing .
(Processing); ScalableList; Index 46 outside the allowed range [0;;45]
as shown aboce when i press Print in PDF the error is ahowing . Can anyone help me…
Hi Suresh,
did you try print preview and then print to pdf…?
Hi Anil ,
Yes , I tried . But print preview is also showing the same error.
Hi Suresh,
Please take a look if this could help out.
http://support.microsoft.com/kb/2485396
you may need to talk to your IT admin to add this update to the sql server.
Good luck!
Anil.
Hi Anil,
Thanks, here mentioned that this error is caused by HideDuplicate property is not set to None.
But it is set to None. no issue about that. But still it is getting error…
