Goods Movement, AX 2012
Hello,
I am trying to locate one report that gives me information on all goods movement in all items. Currently I use two separate options; Transfer Journal and Movement Journal; but that does not give me the receipts. Is this the best standard report available or is there a better option?
Thanks & Regards,
This may help :
Go to Stock and warehouse management > Inquiries > Transactions > Transactions
You can generate a report using this form using autoreport
Splendid !!! Makhan !!
Thanks a lot.
Can the suggested report also have transaction wise Audit Trail. In personalize\add field\Inventory Dimension, when I select Modified date & time and add, this comes in the personalization window & then in my report but when I add Owner and add, this does not come in the personalization window even. Any clue!
Any other means to track modification/origin date and owner. I can see data with modification date of 1st July and physical date of 8th July !!
