Does anyone know if can block form right click > go to main table form through AX user permission?
Regards
Regards
On version 2009 , you can block it with security keys. But if you don’t have a security key that allow you to see the related table , you may as well lose your lookups and auto-lookups that automatically refer to these records.
Every field have a method that can be overridden name JumpRef, this is the guy that controls the go to main table. So if the guy have a certain permission to see the field, the table and the menu item of the target location, but you still don’t want him going to that form with the “got o main table” feature, you need to comment the super() line of code in the jumpRef method.
Hi
Please follow this link to enable or disable “go to main table”. Blog by:Santosh Ramamurthy
http://axblog4u.wordpress.com/2009/07/09/enabledisable-keys-using-task-macro-in-dynamics-ax/
Hi Hako,
It s simple.
Give no access to all the related forms but make sure that you give access at table level.
I hope this will suffice.
Thks lot.
