HI All,
In the Table I want to use a variable value at several places in the same table display method.
For this purpose i need to define a global variable in the table.
How to do this?
please explain with example.
thanks,
HI All,
How to do this?
thanks,
You can’t define instance variables in tables. Consider saving the state in your form or changing the design completely, e.g. having using a temporary table (with all values calculated at once) instead of display methods.
