Global Dimension Code
Hello,
In this page there are just two global dimension codes as mentioned in red…how to add all global dimension codes to this page…
Global Dimension code 1
Global Dimension code 2
Global Dimension code 3…
Global Dimension code 8
TY :slight_smile:
As per functionality you can define two global dimensions and rest of the dimension you can define as Shortcut Dimensions.
Take a look at form 39 General Journal, and look specifically at how the object manages the controls related to array elements in ShortcutDimCode array. This is a typical example of how to place Shortcut Dimension codes onto a page or form.
