Hello,
When journal is deleted, it gets reassigned at the next available opportunity. Our client wouldn’t like to have that done, so the journal numbers can be in sequential order. How they can do that?
Bee
Hello,
Bee
General Ledger/Setup/Parameters then right click and go to main table for number sequence for Journal Number and uncheck continuous. If you want it to re-use numbers then you check continuous.
