GL journal upload with Excel add-in
The header is uploading fine but with no lines.
  1. I input the same ‘dummy’ value in the journal batch number (in bother header & lines) & voucher (in lines).
  2. When I created my template witht the Dynamics AX add-in in Excel, the journal lines brought in “RecId” which I left blank in my upload test.
  3. The line contained these fields
    1. Currency
    2. Journal batch number
    3. RecId
    4. Voucher
    5. line number.date
    6. line number.account type
    7. description
    8. company accounts
    9. ledger dimension
    10. ledger dimension.mainaccount
    11. ledger dimension.store
    12. ledger dimension.department
    13. ledger dimension.division
    14. ledger dimension.customer
    15. debit
    16. credit
  4. my default account structure included the dimensions noted (customer allowed blanks)
  5. just two lines in the upload
    1. line 1:
      1. left blank - recid, ledger dimension, ledger dimension.customer
      2. debit - 777.77
    2. line 2:
      2. credit - 777.77
Any ideas on why the lines did not load?
Thanks!!
Hi there,
I am having the same exact issue. Were you able to find out the problem? Thanks in advance. I am able to create the header but not the lines.
