give tititle for Ax instance
Hi friends,
How to give title for Ax instance. When i’m having morethan one instance and when im opening it morethan one instance. It is confusing to find that i’m working on which instance like that.
How can i give title for that.
If you are working with AX2009 / AX2012, you can go to File → Tools → Options → Status bar tab and activate “Show AOS name”. It will show the Instance name (defined in client configuration) in status bar.
Thanks for the info. Yes I can see it in the status bar.
Is it possible for me to see the instance name in Title Bar.
Check this link: http://www.axaptapedia.com/Configuration_in_title_bar
You can modify the example above to suit your need. [B]
