give fields value automatically
I m using Dynamics ax 2009
i have 3 tables with diff fields given
vehiclecharge - vehicle type-enum, vehicle name, utc timedate, chargesperkm-int, city state currency
customer -custid, custname,pick up location and drop location
rental…- vehicle type (look up to vechicle charge),vehicle name( from vehichle charge),city, pick up location, drop location,
kmstravelled , time started ,amount
now in rental form
Now i want to
get corresponding pick up location n drop location should automatically when i put vehicle type and vehicle name in grid as soon as i write i should get pick up and drop location fields automatically filed in a form.
also in field i there which contains kms travelled as soon as i write them i should get calculated amt in amt field
amt= kms*(charges/km)
which method should i use??
the record should be sync with and from vehicle charge and cust table … how do i do this??
Hi Nick,
In order to get the lookup based on some field u can override the lookup method of the field under Datasource>field>lookup(Method).& under that lookup u can write your logic for lookup using query, querybuilddatasource.
And also u can get the lookup using EDT in ax 20009.
For: amt= kms*(charges/km)
Now, when u want the amount field to get filled up automatically then you should overrride the kms(field) modified method and write the query (amt= kms*(charges/km)) and then override the charges/km(field) modified method and write the same query as (amt= kms*(charges/km)).
Using Edt i m having sql error, can u show me an example for look up without edt?
You can syncronize your database once if it gives error on EDT.
For lookup here is the code:
public void lookup()
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tablenum(TaxWithholdTable), this);
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
sysTableLookup.addLookupfield(fieldnum(TaxWithholdTable, TaxWithholdCode));
sysTableLookup.addLookupfield(fieldnum(TaxWithholdTable, TaxWithholdName));
queryBuildDataSource = query.addDataSource(tablenum(TaxWithholdTable));
queryBuildDataSource.addRange(fieldnum(TaxWithholdTable,TaxWithholdCode)).value(strfmt(’!=%1’,TaxWithholdTable.TaxWithholdCode));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
will i get values automatically in grid using this ??
yes
i m Not getting the values automatically i nor in look ups…i want to get automatic value in grid by just selecting the custid is there any method for it …so when i select cust id i get is realative pickup and drop point
sorry got the lookups but not the value in grid automatically…pls also tell any methods so that when i select cutid i get corresponding records of drop and pick up auto matically
hi ,
use datasource modified method for the vehicle type field …
as soon as u change the vehicle type… write as…
vehicle vehicle; ( vehicle table where vehicle type, pick up loc, drop loc are available)
select firstonly vehicle
where vehicle.vehicletype == vehicleds.vehicletype(datasourcemodifying);
if (vehicle)
vehicleds.pickuploc = vehicle.pickuploc;
vehicleds.droploc = vehicle.droploc;
i want to get pick up and drop location from customer table and the current table where i m selecting cusid is rental table so how do i do using two tables u have shown a very nice code but it includes only 1 table…can u pls show with 2 tables
do i need to use pack and unpack methods for it? if yes then how?
chaitanya thanks for reply
by writing the following code i m able to display values automatically but the problem now is that i m getting the pick up and drop location for all the records not for the particular current record…
public boolean modified()
boolean ret;
RentalTable r;
CustoTable custoTable;
int a;
ret = super();
//info(strfmt("%1",RentalTable_CustId.valueStr()));
a = RentalTable_CustId.value();
select firstonly custoTable
where custoTable.CustId == a ; //(datasourcemodifying)
if (custoTable)
r.PickupLocation = custoTable.PickupLocation;
r.DropLocation = custoTable.DropLocation;
RentalTable_PickupLocation.text(custoTable.PickupLocation);
RentalTable_DropLocation.text(custoTable.DropLocation);
return ret;
not getting values in grid still do i need to update or insert records? rest all is completed…
it gives error in update…
