Hi friends,
how to get field value from one Table to another Table?
It means i want to display same value in another table.
please give me reply…
its urgent…
Murali…
Hi friends,
its urgent…
Murali…
The code of button click event of FormA which calls FormB and passes some parameters to that form.
void clicked()
// Args class is usually used in Axapta for passing parameters between forms
Args args;
FormRun formRun;
// Our custom made class for passing complex set of parameters
FormBParams formBParams = new FormBParams();
Array items = new Array( Types::String );
int i;
args = new args();
// Our values which we want to pass to FormB
// If we want pass just simple string we can use 'parm' method of 'Args' class
args.parm( strValue.text() );
// We also can pass enum value to FormB
args.parmEnum( NoYesEnumValue.selection() );
args.parmEnumType( EnumNum( NoYes ) );
// and also can pass a cursor pointing to some record (in our case it is EmplTable )
args.record( EmplTable );
// If we want pass more complex set of parameters we can develop our own class
// just for passing our parameters.
formBParams.parmSomeDate( someDate.dateValue() );
formBParams.parmSomeTime( someTime.value() );
for( i=0; i<ListBox.items(); i++ )
items.value( i+1, ListBox.getText( i ) );
formBParams.parmItems( items );
// Pass our object to FormB
args.parmObject( formBParams );
// Run FormB
args.name( formstr( FormB ) );
formRun = classFactory.formRunClass( Args );
formRun.init();
formrun.run();
formrun.wait();
if( formrun.closedOk() )
answerFromFormB.text( args.parm() );
super();
The code of init method of FormB
public void init()
EmplTable emplTableRecord;
FormBParams formBParams;
Array items;
int i;
super();
// Check for passed arguments
if( element.args() )
// get string parameter
strValue.text( element.args().parm() );
// get enum parameter
if( element.args().parmEnumType() == EnumNum( NoYes ) )
NoYesEnumValue.selection( element.args().parmEnum() );
// get object parameter
if( element.args().parmObject() )
formBParams = element.args().parmObject();
items = formBParams.parmItems();
for( i=1; i<=items.lastIndex(); i++ )
ListBox.add( items.value(i) );
someDate.dateValue( formBParams.parmSomeDate() );
someTime.value( formBParams.parmSomeTime() );
// get record parameter
if( element.args().record() && element.args().record().TableId == TableNum( EmplTable ) )
emplTableRecord = element.args().record();
emplName.text( emplTableRecord.Name );
The code of ok button click event of FromB
void clicked()
super();
element.args().parm( strAnswer.text() );
element.closeOk();
This is the standard code juz use it.it will work.Args class in axapta is generally used for passing values from one form to another
Kalpna
void clicked()
Args args;
FormRun formRun;
int i;
args = new args();
// Run FormB
formRun.init();
formrun.run();
formrun.wait();
super();
public void init()
Array items;
int i;
super();
void clicked()
super();
element.closeOk();
Kalpna
void clicked()
Args args;
FormRun formRun;
int i;
args = new args();
// Run FormB
formRun.init();
formrun.run();
formrun.wait();
super();
public void init()
Array items;
int i;
super();
void clicked()
super();
element.closeOk();
Kalpna
if i want to write the following method what would be the code?
will help this method initFromSecondTableName() ?
This is the standard code.I have applied the similar code in my forms and it is working .can u explain me the scenario,so that i could better understand the situation.
thanks for reply,
sorry buddy i also don’t know. I am also looking for explanation of this type of methods…
Murali…
