Getting multiple records,whn i save the address
Hi Everybody, In “\Forms\VendTable”, ?In Address Tab when i enter a new address(record) and save it,the same record gets saved 8 times.Can someone help me resolve this issue.
Hi Rajee,
check this object in user layer or not…
if it is in user layer then check any code is there…
Have you done any changes to the standard form. Probably the Join source and link type properties.
Use the compare tool to figure out the changes…
As you are modifying this area (http://dynamicsuser.net/forums/p/40202/207659.aspx#207659) you have clearly caused this, so you need to fix it [:D]
