hi,
Argument_args is a incompatable with required type…
how to solve this error,
i created a menuitembutton, thn i just pass the value to class, its show this error while running
pls help me
thanx
hi,
pls help me
thanx
How you are passing and what value you are passing to the class?
Check the argument types you are passing to the function…Suppose when the function is defined to pass only the int values and you are passing some other datatypes then you will run into this exception…
