I have generated Pages.xml file using Transformation Input Tool. When i try to import the pages.xml file showing the below error “ObjectID must not be blank. ObjectID is missing or invalid in the expression.”
What kind of objects did you transform? Where there main forms without subforms?
What I surely would try is try to indetify which page object gives this error message (in case you have multiple pages in the pages. xml).
I have transferred List Form into List Page. though i am getting this error.
I have compared the .xml file generated by the Transformation tool for list page and the list page which i have exported as .xml and I found that the XML tags are different Such as in the .xml file generated as “Page ID” but in the file which i have exported as “ID”.
Why has it happened. Any idea?
