getting error "Transfer number sequence framework tables." while data upgradation from ax 2009 to ax 2012
hi,
I am upgrading from ax 2009 to ax 2012 , In Lanuch data upgrade(bulk copy) i get an error in task “Transfer number sequence framework tables.”
err msg says:
Number Gen_00000049 does not match format GenJrn_######.
Microsoft.Dynamics.Ax.Xpp.ErrorException: Exception of type ‘Microsoft.Dynamics.Ax.Xpp.ErrorException’ was thrown.
at Dynamics.Ax.Application.NumberSeq.numRemoveFormat(String num, String format) in NumberSeq.numRemoveFormat.xpp:line 16
at Dynamics.Ax.Application.ReleaseUpdateDB60_Basic.Upgradenumbersequencetables(Boolean _remapEdts, Boolean ) in ReleaseUpdateDB60_Basic.upgradeNumberSequenceTables.xpp:line 186
at Dynamics.Ax.Application.ReleaseUpdateDB60_Basic.Updatenumbersequenceframeworkpostsync() in ReleaseUpdateDB60_Basic.updateNumberSequenceFrameworkPostSync.xpp:line 38
at ReleaseUpdateDB60_Basic::updateNumberSequenceFrameworkPostSync(Object , Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeInstanceCall(Object instance, String MethodName, Object[] parameters)
at Dynamics.Ax.Application.SysDictClass.invokeObjectMethod(XppObjectBase _object, String _methodName, Boolean _tryBaseClass, Boolean ) in SysDictClass.invokeObjectMethod.xpp:line 42
at Dynamics.Ax.Application.ReleaseUpdateDB.Run(String methodName, sysReleasedVersion scriptVersion, Boolean force) in ReleaseUpdateDB.run.xpp:line 52
at Dynamics.Ax.Application.ReleaseUpdateExecute.Run() in ReleaseUpdateExecute.run.xpp:line 41
at Dynamics.Ax.Application.BatchRun.runJobStaticCode(Int64 batchId) in BatchRun.runJobStaticCode.xpp:line 54
at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in BatchRun.runJobStatic.xpp:line 13
at BatchRun::runJobStatic(Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
at BatchIL.taskThreadEntry(Object threadArg)
Has any one come across this issue?
Thanks in advance.
