Getting AIF Fault Exception while creating sales order through SalesSalesOrderService.create service
I am getting following error while creating sales order through SalesSalesOrderService.create service
Document Sales Order Could not be created.### Error Reading Value of Type Date from XML.
Please give me quick reply.
Harshal
It would help if you gave us more information about your scenario.
The error says that a date value can’t be read - maybe you have some date(s) in incorrect format.
Thanks for your quick reply.
I am getting error for the line salesTable.DeliveryDate = Convert.ToDateTime(“2/14/2010”); in C#.
while consuming SalesSalesOrder.create service of AX 2012.
Okay, now the problem is obvious - the C# code will throw FormatException with a clear message: “String was not recognized as a valid DateTime”. That’s because the string (2/14/2010) is not in the right format for the current culture. For example, it’s valid for en-US but not for en-GB.
Either change the text (e.g. to 14/02/2010) or your culture (e.g. System.Threading.Thread.CurrentThread.CurrentCulture = System.Globalization.CultureInfo.CreateSpecificCulture(“en-US”)).
I am still continuing with the same error
Error Reading Value of Type Date from XML under
System Admin->Periodic->AIF->Exception
I am Still Continuing with the same error
Error Reading Value of Type date from XML under
I am also facing the same problem.
When I am creating sales order using SalesSalesOrder service from Visual Studio C#.NET, its showing following exception :
"Document Sales order could not be created. Error details: Stack trace: Invalid attempt to call RunBase.promptOnClient running in CIL on the client."
Kumar, it’s not the same problem. You’re trying to execute client-bound code (RunBase.promptOnClient()), which isn’t possible, because the web service runs on AOS without any AX client.
Hi Martin,
I have a VMWare with AX 2012 installed in one box with client and server. should I uninstall client and run. Then reinstall to check it?.
No, the problem is in your code - it tries to open a dialog (promptOnClient()), which doesn’t make sense if it runs in a non-interactive session on AOS.
Hi Martin,
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using SalesOrder.SalesOrderService;
namespace SalesOrder
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
try
SalesOrderServiceClient client = new SalesOrderServiceClient();
AxdSalesOrder salesOrder = new AxdSalesOrder();
AxdEntity_SalesTable salestable = new AxdEntity_SalesTable();
AxdEntity_SalesLine salesLine = new AxdEntity_SalesLine();
CallContext callContext = new CallContext();
EntityKey[] keys;
EntityKey key;
KeyField fld;
CallContext context = new CallContext();
context.Company = “ceu”;
salestable.CustAccount = “1101”;
salestable.PurchOrderFormNum = “”;
salestable.ReceiptDateRequested = Convert.ToDateTime(“2/1/2012”);
//new DateTime(2013, 11, 15);
salesLine.ItemId = “1000”;
salesLine.SalesQty = 1;
salesLine.SalesUnit = “ea”;
salestable.SalesLine = new AxdEntity_SalesLine[] { salesLine };
salesOrder.SalesTable = new AxdEntity_SalesTable[] { salestable };
salestable.PurchOrderFormNum = “PO15”;
callContext.Company = “ceu”;
callContext.Language = “en-us”;
keys = client.create(callContext, salesOrder);
key = keys[0];
fld = key.KeyData[0];
MessageBox.Show(“Sales Order” + fld + “Created success fully”);
catch (Exception ex)
string msg = ex.Message;
Kumar, RunBase class is defined in AX, therefore you have to deal with the code in AX that’s calling it. If you don’t know where it’s called, use debugger.
