I have a custom report i am adding more fields to… in I already have Item/Item ledger entries tables returning records… I am needing to add the jobs table… in the report under
Item Ledger entry - OnAfterGetRecord() i am using JobRecord.Get(“No.”);
I amrunning into a problem where some of the Item Ledger entries do not have a Job number association. So when i run the report i have the error Job No. ‘’ does not exist. I presume what i need to do after the GET is say
IF JobRecord.Get(“No.”) <> ‘’ then JobRecord.Get(“No.”)
Else JobRecord.Get(’’) ;
but this gives me a syntax error. Is there anyone that has suggestions of examples of this type of syntax?
