On the “Reservation Entries” page there is a field called “Reserved for”, which I need to also appear on the “Purchase Order Subform” page, for which I am developing an extension.
On the Reservation Entries page, this field uses the “CreateForText” procedure of the “Reservation Engine Mgt.” Codeunit
This procedure requires a parameter of type Record “Reservation Entry”
In my extension of the page “Purchase Order Subform”, I want to use this same procedure, but I need the parameter “Reservation Entry”, which would be the reserved in each line of the table “Purchase Line”.
I have noticed that the “Source ID” and “Source Ref. No.” fields of “Reservation Entry” refer to the fields “Document No.” and “Line No.” from Purchase Line, so in my extension I want to create a variable of type Record “Reservation Entry”, but that meets the criteria “Source ID” = “Document No.” and “Source Ref. No.” = “Line No.”, how could I do this?
I had planned to use the “Get” method of “Record”, but this only allows to use the primary key as a filter, and I would like to use the fields “Source ID” and “Source Ref. No.”
