Get printer on runtime - possible
Hi all I’m looking for a possibilty to get the printer on runtime of the report. I need to know if the report is printed as pdf. Then we have to add some text lines to the report. bye André
Hi Andre direct solution is anknown to me, but I use a workaround in such a case: Make two steps: Put it all in a codeunit then first in the codeunit let the user choose the print in a navision form (perhaps you simulate HERE the requestform of report) then bind the printer to the report (Perhaps pass parameter to report) start report without requestform
Hi Hans Thnak you for your suggestion. I made the simple ‘UserAction’ - work-around. He has to select a True/False - field if he wants to print this report as pdf. bye André
