Get parameter of form
Hil All,
My form is calling by formref property from a field of any table. I need value came from that tables field.
formRef = findProperty(sysDictTable.treeNode().AOTgetProperties(),#PropertyFormRef);
will you please give some detail of your requirement.
Sorry this is about my poor english:
I created table “a_table”
I created a form for it “a_table_form”
I created a menu item “a_table_form_menu” for “a_table_form”
I referred “a_table_form_menu” to formref property of “a_table”
I want to know passed value at “a_table_form”'s init.
I can learn that value by get args.record() for a specific table, but “a_table_form” is calling from different tables, different field names so I don’t want to put a switch command for every table.
This is the way, you can see examples if you find other forms. One thing you can do is to create a class an implement a factory method, in the form you have the parent class as reference type.
I found the solution from a blog:
FormStringControl   callerControl   = SysTableLookup::getCallerStringControl(element.args());
info(callercontrol.text());
http://axapta.blogcu.com/lookup-form/1008636
