Get Order Number from Posted Return Rcpt
hi everyone,
anyone knows how to retrieve original sales order number from POSTED sales return receipts? [8-)]
If you had user use copy document to creat the return, the document copied number will be on the first line. A better solution is to require that the user choose the appl. - from Item Entry which would tie it to the original Shipment and you could tie back to the order from there.
If the user isn’t doing anything to tie the return to the original sale, there is not a way you can get back to the original order.
hi teresa,
thats bad… sigh, so the only way is to search for the description text and check by SO**-**** ?
