get number sequence whole value
Dears
Simply , i need to get the full number sequence value like “Invent_11101” for example my code in below
inventTable = InventTable::find(LEVPrintOrder.Lev_ExamTypeCode);
inventNumGroup = InventNumGroup::find(inventTable.BatchNumGroupId);
numberSequenceTable = NumberSequenceTable::find(inventNumGroup.NumberSequenceTable);
seq = new Sequence(numberSequenceTable.Txt,numberSequenceTable.RecId,numberSequenceTable.Lowest,numberSequenceTable.Highest);
lEVMakeRelationCoreTable.Lev_BookNumberSeqTo = int2str(seq.currval(LEVPrintOrder.dataAreaId,numberSequenceTable.RecId));
because currval() return integer value only reflect the number sequence ,but i need the whole value like"invent_11101",waiting your reply your help highly appreciated ,thanks
Hisham.
hi hisham,
I am new in Ax, I dont know much about number Sequence but i had made a program where in you have to input two values and the sequence will be generated in click of a button. As per your requirement i think you can use my code to generate number sequence and then concatinate with the string and show in you form. If you want to do this way then i can give you code i wrote to generate cheque number and there by you can generate sequence number. let me know if you need this sort of code.
I hope this can help you.
Himanshu.
himanshu_ax@yahoo.com
You may use something like NumberSeq::numInsertFormat(numberSequenceTable.NextRec-1, numberSequenceTable.Format);
I thing you shouldn’t use the Sequence class at all.
Hii ,
Thanks on your reply , could you send me your code for this function? ,waiting for your reply .
KR,
Hisham.
Just try the below code,
NumberSeq numberSeq,
TransactionId transactionID // its jst a variable
numberseq = NumberSeq::newgetVoucherFromCode(NumberSequenceTable::find("YourNumberSequnceID).NumberSequence;
transactionID = numberSeq.voucher();
the number sequence assign into the transactionID
