Get name of security task
Is there any method(classes) to retrieve security object name(AotName) by using its RecID(SecurityTask) …
without using select statemt for SecurityTask table.???.
hi,
Pls move this to developer forum(How to move…??)…
Moved to developer forum.
You mean this field \System Documentation\Tables\SecurityTask\Name?
Yes…Kranthi…
I haven’t found any such method. You can directly write a select.
Even there was a method, the method would have to do a select.
