Through an SQL query i want to be able to see what NAV users have been given access to a certain menu, is this possible?
Ie when I right click on the menu in NAV and go assign users and the list comes up, somehow in SQL i want to show a list of users that have been allowed access to specific menu’s if i send in the menu name
Well, basically there is the “User Menu Level” table you could query …
SELECT
“ID”,
CASE WHEN “ID Type” = 1 THEN ‘Database’ WHEN “ID Type” = 2 THEN ‘Windows’ END AS “ID Type”,
CASE WHEN “Level” = 10 THEN ‘User Restrictions’ WHEN “Level” = 20 THEN ‘User Changes’ END AS “Level”,
“Modified”,
“Object”
FROM “User Menu Level”
… but I guess this helps not much, as the “Object” is in binary format.
What are you trying to accomplish? Maybe there could be some workaround!?
