Get first record selected from multiselect grid and pass it to a report
I need to get the record i selected first from a multiselect grid of form.
Ex: from Transfer order form i select say TO: 18,20,21,19 in this order. Then i require to get TO:18 and its corr details.
I tried using InventTransferTable_ds.getFirst(1);
However it return the TO19 ie: one i selected latest. i want the first one.
Also i need to pass this TO no from form to class and to report. this report is called from class that extends RunBaseReport class.
Please guide for the same.
Thanks !
hi …
this is the code for multiselected records …
void clicked()
MultiselectProject Multiselect;
real i;
Multiselect = MultiselectProject_ds.getFirst(1,true);
while (Multiselect)
i += Multiselect.marks;
Multiselect = MultiselectProject_ds.getNext();
info(strfmt(“You selected student %1”,i));
Hi ,
Thanks for your reply but this does not give me the records in the order of my selection of records in the grid :frowning:
Hi ,
Override the “Enter” method of Grid and write the logic using Multiple flag ,where one flag is used at form level and other at table level using Table_ds.cursor() .
Verify if the solution meets your requirement.
:slight_smile:
