Get field property on AOT
Is there any sample code that I can use to find out all the fields in the tables that are using EDT “PurchId”?
Thanks a lot,
It’s not a sample code but you should see what you’re looking for: search you EDT in AOT, then right clic, Complementary Programs, Cross-references, use
PurchId is used a lot in AX, so you’ll have a lot of results
Hope it helps,
Regards
Thomas
DataReferenceSearcher can do that (considering even child EDT’s). And if it doesn’t do exactly what you want, just look into code and borrow what you need.
