Get a record in lookup with allowedit false
Hello AX,
I have a product creation form, it has two lookup itemId and ProfilID, both lookup are not editable or Selected, the goal is when I filled the form and I selects status: I have to create the validated object and at the same time create record for each lookup and display the form in view mode , I want the record created, appears on lookup on field ItemId and ProfilID
thank u for ur help
Happy Daxing
Best regards
Can you make it more clear?
Here the interface, I have two lookup fields elusive when I create a new enregisrement , I want the lookup takes two new record values when raffraishisement of the page
Still your requirement is not clear.
