Generating UTF-8 without BOM(Byte Order Mark)
I am generating a file in UTF-8 File format. When i open my file through notepad, i can see only my data. But a 3 byte sequence BOM (Byte Order Mark) is getting added at the beginning of the file to indicate that it is UTF-8 file format which is invisible. If i open the file through command prompt, i can see that 3 bytes.
reference: msdn.microsoft.com/…/textio.aspx
msdn.microsoft.com/…/textio.new.aspx
My requirement is that , i don’t want that 3 byte sequence BOM at the beginning of the file but my file should be in UTF-8 file format.
Is there any way to remove the Byte order mark through X++ code
Thanks & Regards
Arun B S
Here is my Job
static void bank_test(Args _args)
FileName fileName;
InteropPermission iopermission;
Textio txioWrite;
#define.UTF8Code(65001)
#define.write(‘W’)
fileName = “C:\Documents and Settings\abs\Desktop\test.CSV”;
iopermission = new InteropPermission(InteropKind::ClrInterop);
iopermission.assert();
txioWrite = new Textio(fileName,#write,#UTF8Code); // #UTF8Code is to generate a file in UTF-8 format
txioWrite.write(“Data 123”);
txioWrite = null;
CodeAccessPermission::revertAssert();
Answered in a parallel thread on another forum.
Quoting the most important part:
If you use .NET, you can exclude BOM by using properly configured UTF8Encoding. It’s done by the parameter of UTF8Encoding’s constructor in the following example (written in X++ using .NET Interop):
<i>System.Text.Encoding encoding = new System.Text.UTF8Encoding(false);
System.IO.File::WriteAllText(@'C:\test.txt', "Data 123", encoding);</i>
