Generate Output of a Report as a Text File?
Hi, Is it possible to generate the output of a report as a text file? I tried using the file functions, but it won’t allow the procedure. Anyone has an idea on how to make it working? Thanks in advance. Sincerely, Sylvia Tsang Management Software Solutions, Inc. stsang@mgmtsoftware.com
After using the marvelous “search” feature of the forum using “report text file” as search string… you can find: Create text file from report http://www.navision.net/forum/topic.asp?TOPIC_ID=2814&FORUM_ID=9&CAT_ID=3&Topic_Title=Create+text+file+from+report&Forum_Title=Attain%2FFinancials+-+Developer+Forum Date December 14… Using the search feature is not forbidden, but really useful… Regards Alfonso Pertierra (Spain)apertierra@teleline.es
Depending on your needs, you could also simply choose to save the report as HTML. Bill Benefiel Manager of Information Systems Overhead Door Company billb@ohdindy.com (317) 842-7444 ext 117
