Does any body know here how to generate invoice through batch job and after that how to check xml for Finvoice?
Which Invoice you are trying to Generate ?
I am assuming if it is a sales invoice on sales order form In action menu you can find Invoice button, if you click on it it opens up a form there you have batch option , click on batch now you can see a window with batch processing checkbox. Check it and if you need recurrence Job select the recurrences and Create/select the batch group. Click ok then the job gets added to batch
