If I’m creating a line in the General ledger journal manually, then when I’m selecting a customer the system is checkng the AutoSettle setup in the custParameters and since it’s set to True, the system sets ledgerjournalTrans.SettleVoucher = OpenTransations
When I’m importing the same journal as a csv file via Data Management and choose std General Ledger Entity , the SettleVoucher field on the imported lines does not get populated. I’m trying to debug the entity code(LedgerJournalEntity) to understand the reason.
I see at no point the settleVoucher population … Also I see no any calls to for example to accountModified() on ledgerJournalTrans (or something similar) to set relevant fields based on the selected customer. Am I missing something? Is it a bug? Or is it so deliberately or am I just looking in a wrong place. Please help !!
I’m looking at an older version of the application (something I have on my local machine), therefore it might look differently in your case, but I see a call of updateLedgerJournalTransSettleVoucher()
in LedgerJournalEntity::copyCustomStagingToTarget()
You could also use LedgerJournalLineEntity
which calls ledgerJournalTrans.setSettleVoucher()
in insertEntityDataSource()
Thank you very much Martin! The thing is that my debugger was never entering those methods despite having breakpoints there, but thanks to you I revisited copyCustomStagingToTarget() again and noticed that in the comments above the method it says that the method is not triggered if the entity has AllowSetBased set to false. If not , the code is just skipping all the logic to gain the performance. I’ve checked the setup and client’s entity was set as SetBased = false. Now I have to understand why after setting SetBased = True the voucher numbers stopped being assigned upon import which was working before the change …Never a dull moment
PS: Found that the voucher should be specified in the import file in case of set-Based
import Importing vouchers by using the General journal entity - Finance & Operations | Dynamics 365 | Microsoft Learn
Actually I still don’t quite understand MS logic here:
I’ve setBased = True on the entity and now the settleVoucher gets populated , i.e I’m getting into the copyCustomStagingToTarget(). This method populates a lot of default fields.
If setBased = False then the default logic is not run
Why is designed that way? Are we in the case of SetBased = false supposed to populate all the fields in the file to be imported rather than relying on AX populating it based on parameters and setups (i.e including settleVoucher)?
When I check DMFEntityWriter.writeV2 , I get it as if the TargetIsSetBased = False,then we just copy data from staging directly to journals. Therefore if the settleVoucher is not present in the the generalJournal entitity field list , I won’t be populated in the jouranl lines. Theerfore, do I understand it correctly that it’s impossible(without customisations) to get settleVoucher populated if entity has setBased = False ?
