Uffff, found anyway… but it was hard task digging thru terabytes of crap accumulated over years on my HDDs
My approach was more universal - the following script creates a VIEW of all defined Dimension Sets in system:
--CREATE VIEW vDimSETS_Pivoted AS --uncomment this to create a permanent VIEW
--which can be linked to Ledgers
SELECT
[Dimension Set ID] AS SetID
-- replace the following with your actual Dim codes
,[AREA]
,[BUSINESSGROUP]
,[CUSTOMERGROUP]
,[DEPARTMENT]
,[PROJECT]
,[PURCHASER]
,[SALESCAMPAIGN]
,[SALESPERSON]
FROM
SELECT
[Dimension Set ID]
,[Dimension Value Code]
,[Dimension Code]
FROM [dbo].[CRONUS Canada, Inc_$Dimension Set Entry]
WHERE [Dimension Set ID] < 20 -- comment WHERE clause out if VIEW is to be created, "<20 "is for testing the script
) AS SourceTable
PIVOT
max([Dimension Value Code]) -- aggregate function here is a MUST, we can use MAX(),
-- it does no harm & complies to required syntax
FOR [Dimension Code]
IN ([AREA],
[BUSINESSGROUP],
[CUSTOMERGROUP],
[DEPARTMENT],
[PROJECT],
[PURCHASER],
[SALESCAMPAIGN],
[SALESPERSON])
) AS PivotTable
examine the script, I tried to comment it at my best, but you know how it stands with those comments
results look like
PIVOT is required to transpose set dimensions in ONE row, because physically they are stored as 1 to n rows where n = count of Dims in a Set. Next script is for demonstration purpose, your issue doesn’t require it.
USE [Demo Database NAV NA (7-1)]
GO
SELECT [Dimension Set ID]
,[Dimension Code]
,[Dimension Value ID] --is unique throughout the table, even for different DimCodes, can be used to get Dim NAME as follows
,(SELECT [Name]
FROM [dbo].[CRONUS Canada, Inc_$Dimension Value] DV
WHERE DV.[Dimension Value ID] = DSE.[Dimension Value ID]) as [Dimension Name]
FROM [dbo].[CRONUS Canada, Inc_$Dimension Set Entry] DSE
WHERE [Dimension Set ID] = 11 -- debug (to eliminate the output while testing)
GO
Then, link the VIEW vDimSETS_Pivoted in your scripts with any Ledger Table as needed, not only G/L Ledger. All Ledger tables (+some other, too, BTW) contain field [Dimension Set ID]
Hope this helps,
