G/L Dimension Mis-Posting
Dear all, there is a phenomenon that I have discovered with Dims in G/L. while the user may enter the dimensions, especially those coming from another module, the system may post G/L Entries without writing to the Ledger Dimension Entry table. As a result, you have G/L entries that bear no dimensions (click Entry, G/L Dimension Overview once you have drilled from the chart of accounts). This is something that may not be discovered until may be you try to use Dimension Analysis! Now my question: is there anyone who has already encountered and solved this, so I dont have to re-invent the wheel, or rather who know if this has been handled in a certain Hotfix? Thanks, Robert
