Function InvestCostTransCostList: new PlannedCostList has been used incorrectly
Upon posting the purchase order invoice, the below error prompted:
Has anyone encountered the same?
Thank you very much!
Heylin
Has anyone encountered this kind of error?
Can you tell us some steps to reproduce the issue?
Hi Kranthi,
The user enter the PO as usual, posted as PO and Packing Slip as usual. But upon posting the invoice above error prompted.
Heylin
I would suggest you get a developer to debug it.
If you have converted an item into a standard costing item and the current posting date is less than the conversion date then this can lead to the current situation. Verify this in your case.
Activation of the cost is 11/15/2012 and posting is 11/16/2012.
Even if I try to reverse the Packing Slip, same error prompts. :frowning:
Hi Kranthi,
I found out that the posting date is less than the conversion date. I plan to create a new PO for this but before I do that, I need to reverse the packing slip first. However, as I try to post negative packing slip, same error prompts. Do you know how to reverse the packing slip transaction for this? Or can you suggest any work around?
I appreciate your help!
Heylin
Oh I see that the activation date of the purchase price is 3/7/2013 while the transaction being posted is 11/16/2013.
