Function EVALUATE in RTC
Hi !
I write this code :
EVALUATE(OptionNo, FORMAT(pioFldRef.VALUE))
message(format(OptionNo))
In classic the result is 0 (index of option Quote)
but in RTC result is Quote
So In classic is worked but in RTC an error message is generated
Someone have an idea how i can have the index of option Quote in RTC ???
THX ^^
I’m pretty sure if you take off the FORMAT it will work fine (untested). So just pioFldRef.VALUE will give you the number. I can’t remember if this is different when you are using references.
