FRx Data Refresher for NAV on SQL 2008
Is FRx Data Refresher (Integration Designer) for NAV compatible with SQL server 2008?
The system requirements documentation goes only as far as SQL 2005. It doesn’t say anything about SQL 2008. When we try to install the Data Refresher on a server with SQL 2008, it says that the SQL server is not found. Does anyone know if it is compatible with SQL SVR 2008 or is there is a way to find out?
I would doubt that Microsoft supports this. Here is the last requirement page I could find.
It doesn’t even say that it runs with SQL 2005. I don’t know SQL 2008 yet, but maybe it has a compatibility setting just like SQL Server 2005, that would help you.
