freezing multiple records in grid
here i m using dynamics ax 2009 … in my form ( sample table) fields are given ( sample Id , name , status) .
if my record status is open order selected records would be unfreeze … once i post the record it will be freezed … can any one help me for to freeze multiple records once i posted …
Please see my answer in your thread with the same name on another forum.
Hi all …
i got answer for freezing by selecting multiple grid records in form … here i use button click method for freeze grid records … below coding i using for it … working correctly
public int active()
int ret;
ret = super();
if(SampleTable.Permissions == permissions::No)
SampleTable_DS.allowEdit(false);
Button.enabled(false);
else
SampleTable_DS.allowEdit(true);
Button.enabled(true);
return ret;
// This click method is used to freeze the multiselected Records in the Grid
// by using container Class
void clicked()
SampleTable sampleTable1,sampleTable2;
container con,conId;
int i,j;
i = 1;
sampleTable1 = SampleTable_DS.getFirst();
sampleTable2 = SampleTable_DS.getFirst();
for(sampleTable1 = SampleTable_DS.getFirst(true) ? SampleTable_DS.getFirst(true) : SampleTable_DS.cursor();sampleTable1;sampleTable1 = SampleTable_DS.getNext())
con = conins(con,i,sampleTable1.Status);
if(conpeek(con,i) !=0)
throw error("@PER218");
conId = conins(conId,i,sampleTable1.RecId);
i++;
for(j = 1 ; j <= conLen(con);j++)
if(conpeek(con,j) != 0)
else
ttsbegin;
while select forupdate sampleTable1 where sampleTable1.RecId == sampleTable2.RecId
sampleTable.Status = statusIdea::Posted;
sampleTable.Permissions = permissions::No;
sampleTable.update();
ttscommit;
SampleTable_DS.reread();
SampleTable_DS.refresh();
SampleTable_DS.active();
SampleTable_Ds.research();
super();
public void init()
super();
this.query().dataSourceTable(tablenum(SampleTable)).addSortField(fieldnum(SampleTable,RecId),SortOrder::Descending);
Kavin, please mark the question as answered.
Hi everyone please find the attachment … i keep complete coding in this attachment
5684.freeze the multiple records in grid.txt (2.13 KB)
click() one error in previous code i post it mistakenly … here i put correct coding please check this one …
freeze the grid multiple records
public class FormRun extends ObjectRun
public void init()
super();
public int active()
int ret;
ret = super();
else
return ret;
void clicked()
container con;
int i;
i = 1;
i++;
for(sampletable2 = SampleTable_DS.getFirst(1) ? SampleTable_DS.getFirst(1) : SampleTable_DS.cursor(); sampleTable2; sampleTable2 = SampleTable_DS.getNext())
ttsbegin;
sampleTable1.Status = statusIdea::Posted;
sampleTable1.Permissions = permissions::No;
sampleTable1.update();
ttscommit;
SampleTable_Ds.research(true);
super();
