How can i reduce "the length of the text string exceeds the size of the string buffer", this error message prompt up while importing transform page in NAV2009. I need your help sir, thanks.
Is it showing line no? if so, try to go to that line in text file & segregate the lengthy line to new lines.
No, line is not shown. I open the transformed page wit notepad.
<?xml version="1.0"?> Yes Document Table50050 WHERE(Next Call Date.=FILTER(<>''), For Appt Confirmation=CONST(Yes)) Yes <![CDATA[BEGIN VALIDATE("Service Item"); VALIDATE("Customer No.");CALCFIELDS(“Total Hour Available 4 day”);
ServiceSetRec.GET;
“Total Appointment Time” := (“Total Hour Available 4 day” * (ServiceSetRec.“Appointment %”/100));
“Total Walk in Time”:= (“Total Hour Available 4 day” -“Total Appointment Time”-ServiceSetRec.“Carry Over”);
“Total Rem W/I Time” := (“Total Walk in Time” - “Walk-In Allocated Hr”);
“Total Rem Appt Time” := (“Total Appointment Time” - “Appointment Allocated Hr”);
OnAfterGetCurrRecord;
END;
1900000004
1000000066
No
ENU=Generate Appointment
Yes
Process
1000000075
ENU=Generate Customer Order Form
Yes
Process
1000000148
ENU=Up&date
Yes
Process
<![CDATA[VAR
ApptnSchedule@1000000002 : Record 50065;
ApptnSchedule2@1000000003 : Record 50065;
HourSlotInfo@1000000001 : Record 50064;
BEGIN
TESTFIELD(“Customer Order Form No.”);
IF NOT CONFIRM(‘Do you want to continue?’,FALSE) THEN
ERROR(‘Update aborted!’);
// update hour slot info
HourSlotInfo.SETRANGE(Technician,“Technician Code”);
HourSlotInfo.SETRANGE(Date,“Customer’s Preferred Date”);
HourSlotInfo.SETRANGE(HourSlotInfo.“Hour Slot”,“Starting Hour”);
HourSlotInfo.SETRANGE(“COF No.”,“Customer Order Form No.”);
IF HourSlotInfo.FINDFIRST THEN
ERROR(‘Schedule already exists!’)
ELSE BEGIN
ApptnSchedule2.SETRANGE(ApptnSchedule2.“Technician Code”);
IF ApptnSchedule2.FINDLAST THEN
ApptnSchedule.“Entry No” := ApptnSchedule2.“Entry No” + 1
ELSE
ApptnSchedule.“Entry No” := 1;
ApptnSchedule.VALIDATE(“Technician Code”,“Technician Code”);
ApptnSchedule.“Schedule Date” := “Customer’s Preferred Date”;
ApptnSchedule.“Technician Name” := “Technician Name”;
ApptnSchedule.“Job Category” := “Service Type”;
ApptnSchedule.“Daily Man Hour” := “Man Hour Per Day”;
ApptnSchedule.“Hours Consumed” := “Service Slot”;
IF NOT ApptnSchedule.INSERT THEN ApptnSchedule.MODIFY;
HourSlotInfo.Technician := “Technician Code”;
HourSlotInfo.Date := “Customer’s Preferred Date”;
HourSlotInfo.“COF No.” := “Customer Order Form No.”;
HourSlotInfo.“Line No.” := 10000;
HourSlotInfo.“Daily Man Hour” := “Man Hour Per Day”;
HourSlotInfo.“Hours Consumed” := “Service Slot”;
HourSlotInfo.VALIDATE(“Hour Slot”,“Starting Hour”);
IF NOT HourSlotInfo.INSERT THEN HourSlotInfo.MODIFY;
END;
MESSAGE(‘Schedule updated successfully’);
END;
1000000062
ENU=&Functions
Report 50184
ENU=Print Customer List
1000000081
1900000001
1000000000
ENU=Maintenance Reminder
1000000009
“Customer No.”
1000000082
“Customer Name”
1000000084
Address
1000000019
“Contact Person”
1000000021
“Phone No 1.”
1000000023
“Phone No. 2.”
1000000027
“E-Mail”
1000000069
“Send Appointment Message”
1000000090
Page50174
VDS=FIELD(VDS),
Fault Code=FIELD(Service Code),
COF No.=FIELD(Customer Order Form No.)
1000000171
“Customer’s Requests”
Appointment;Walk-In;Others
1000000150
Maintenance2
ENU=Maintenance
1000000109
Internal
1000000110
“Technician Code”
1000000112
“Technician Name”
1000000097
“Man Hour Per Day”
1000000100
“Service Slot”
1000000117
ENU=Delivery Date
1000000120
“Customer’s Preferred Time”
ENU=Delivery Time
1000000143
“Starting Hour”
1000000025
“Technician Code2”
1000000061
“Technician Name2”
1000000177
“Job Details”
1000000172
Maintenance3
1000000067
VDS
1000000145
1000000142
“Ending Hour”
1000000156
“General Repair”
1000000173
Text19030493
1000000160
“Diag/Est”
1000000155
“Customer Waiting”
1000000159
“Customer Complaint”
1000000001
“Service Item”
1000000003
“Engine No.”
1000000005
“Chasis No.”
1000000007
“Model Code”
1000000091
“Model Year”
1000000073
“Contact E-Mail”
1000000071
“Send Appointment Reminder”
1000000151
“Walk-In”
1000000105
VIS
1000000123
“Serving Store”
1000000128
FALSE
“Remaining Hours”
ENU=Tech Remaining Hrs
1000000130
FALSE
1000000132
FALSE
1000000134
FALSE
1000000136
FALSE
1000000163
“B & P”
1000000089
Text19033859
1000000086
Text19059898
1000000147
FALSE
1000000149
FALSE
1000000165
Warranty
1000000166
“Repeat Repair”
1000000011
“Service Code”
“Faulty Material setup Header” WHERE (Service Item Model=FIELD(Model Code))
1000000013
Description
1000000015
“Service Due Projected Date”
1000000017
“Service Expected Duration”
1000000064
“Next Call Date.”
1000000031
“First Call Date”
1000000033
“First Call No.”
1000000035
“First Call Contact”
1000000037
“First Call Response”
1000000039
“Repeat Call Date”
1000000041
“Repeat Call No.”
1000000043
“Repeat Call Contact”
1000000045
“Repeat Call Response”
1000000047
