Format Function
I need a decimal format with 2 decimal after comma
If decimal number is 654,44 it is OK
But if decimal number is 654,40 the result is 654,4
And if decimal number is 4,00 the result is 4
How can I do it?
I am using this format:
FORMAT(Amount,0,’<Comma,.>’)
The data format for Amount is decimal.
I think you want <Decimals,2>. A lot of the format strings have options second “parameters” that you can pass. Same with dates, if you want the month to be 09 instead of 9 for example.
With this solution, in same cases I have ** instead of values??
Do you know Why???
I am using the format d«function on a XML file:
X := FORMAT(Amount,0,’<Comma,.><Decimals,2>’);
It will display *'s if there is not enough space on the screen.
Matt
But this is not a report, this is a XML File, so there is enougth space.
In a XML file how can I avoid ** in output file?
