FORMAT(DecVar,0,'<Precision,4:4><Integer><Decimals>') fails in NAV 2013 R2
Gotta a strange error in something I have used many times. Now in NAV 2013 R2 this doesn’t work.
Dummy := FORMAT(DecVar,0,’<Precision,4:4>’)
When I run this code I’m faced with this error:
An invalid field or attribute has been specified for the ‘Format’ property.
<Precision,4:4>
Exactly what did I miss here?
The expected outcome is a text (Dummy is a text var used for testing this) formatted like ‘13.0200’.
If I changed the code to:
Dummy := FORMAT(1,0,’<Precision,4:4><Standard Format,9>’)
Then Dummy returns ‘1’ - not ‘1.000’ as expected.
Did you try <Precision,4:4>
Yes. The strange thing is while
returns ‘1’
FORMAT(0,0,’<Precision,4:4><Standard Format,9>’)
returns ‘0.0000’.
So I did a workaround, like this:
IF DecVar = 1 THEN
DecString := '1.0000’
ELSE
DecString := FORMAT(DecVar,0,’<Precision,4:4>’);
Any other suggestions?
