Form Transformation to Page
I am trying to transform a form into a page from NAV 2009R2 but its not creating any pages. This is the text file error am getting.
Any assistance is highly appreciated.
thanks
------------ Transformation started at 01/03/2013 22:51:09 ------------
Forms file: .\Forms.xml
Pages file: .\Pages.xml
InsertElements file: .\TransformPages.xml
IgnoreForms file: .\IgnorePages.xml
DeleteElements file: .\DeleteElements.xml
MoveElements file: .\MoveElements.xml
RenumberPages file: .\MovePages.xml
CodeRules file: .\coderules.txt
---- Transformation finished 01/03/2013 22:51:10. Duration 5 sec ----
------------ Transformation started at 01/03/2013 22:57:10 ------------
Error: Schema: \ApplicationObjects.xsd
Error: Form -2: The validation for file:///D:/Drive d/Navision/Dynamics.NAV60R2.W1.32012.DVD/TransformationTool/ApplicationObjects.xsd.tmp.xml failed. Detailed Information: LineNumber=161, LinePosition=14
Error: Form -2: The element ‘Properties’ in namespace ‘urn:schemas-microsoft-com:dynamics:NAV:ApplicationObjects’ has invalid child element ‘Style’ in namespace ‘urn:schemas-microsoft-com:dynamics:NAV:ApplicationObjects’. List of possible elements expected: ‘Description, Editable, Enabled, InstructionalTextML, ShowAsTree, IndentationControls, Visible, GroupType, IndentationColumnName, Name’ in namespace ‘urn:schemas-microsoft-com:dynamics:NAV:ApplicationObjects’.
Error: Some input file can’t be validated by schema. Please, correct it and rerun tool again
------------ Transformation started at 01/03/2013 22:58:26 ------------
------------ Transformation started at 01/03/2013 22:59:56 ------------
------------ Transformation started at 01/03/2013 23:00:30 ------------
------------ Transformation started at 01/03/2013 23:05:14 ------------
---- Transformation finished 01/03/2013 23:05:15. Duration 1 sec ----
------------ Transformation started at 01/03/2013 23:08:32 ------------
---- Transformation finished 01/03/2013 23:08:32. Duration 1 sec ----
------------ Transformation started at 01/03/2013 23:13:05 ------------
---- Transformation finished 01/03/2013 23:13:05. Duration 1 sec ----
------------ Transformation started at 01/03/2013 23:20:21 ------------
Error: Form -2: The validation for file:///D:/Drive d/Navision/Dynamics.NAV60R2.W1.32012.DVD/TransformationTool/ApplicationObjects.xsd.tmp.xml failed. Detailed Information: LineNumber=209, LinePosition=14
------------ Transformation started at 01/03/2013 23:22:17 ------------
Error: Form -2: The validation for file:///D:/Drive d/Navision/Dynamics.NAV60R2.W1.32012.DVD/TransformationTool/ApplicationObjects.xsd.tmp.xml failed. Detailed Information: LineNumber=73, LinePosition=14
------------ Transformation started at 01/03/2013 23:29:14 ------------
------------ Transformation started at 01/03/2013 23:32:09 ------------
---- Transformation finished 01/03/2013 23:32:10. Duration 1 sec ----
------------ Transformation started at 01/03/2013 23:36:03 ------------
Error: Form -2: The validation for file:///D:/Drive d/Navision/Dynamics.NAV60R2.W1.32012.DVD/TransformationTool/ApplicationObjects.xsd.tmp.xml failed. Detailed Information: LineNumber=81, LinePosition=14
------------ Transformation started at 01/03/2013 23:38:09 ------------
------------ Transformation started at 01/03/2013 23:38:16 ------------
------------ Transformation started at 01/03/2013 23:39:17 ------------
------------ Transformation started at 01/03/2013 23:40:51 ------------
------------ Transformation started at 01/03/2013 23:47:06 ------------
Error: Schema: \TransformationInput.xsd
Error: Form -2: The validation for file:///D:/Drive d/Navision/Dynamics.NAV60R2.W1.32012.DVD/TransformationTool/TransformationInput.xsd.tmp.xml failed. Detailed Information: LineNumber=7, LinePosition=9
Error: Form -2: The ‘urn:schemas-microsoft-com:dynamics:NAV:ApplicationObjects:PageType’ element is invalid - The value ’
’ is invalid according to its datatype ‘urn:schemas-microsoft-com:dynamics:NAV:ApplicationObjects:PageTypeType’ - The Enumeration constraint failed.
Error: Form -2: The Enumeration constraint failed.
------------ Transformation started at 01/03/2013 23:53:18 ------------
Following link will help you
http://msdn.microsoft.com/en-us/library/dd338923.aspx
Are you sure you exported your forms in xml format?
I too feel the same as I can see error message related to STYLE and which exists in Pages…
Hi Joshpat,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
Dear Josphat,
The following error having different solutions. for my knowledge i am sharing some tips to rectify this problem.
  1. Check the ToolTip Properties on form fields.
  2. Check FontBold, FontItalic, FontStrikethru properties on form fields. these properties not allowed to validate RTC client [Y]
remove all frames from the forms. then try again by transforming forms with all subforms. that should work.
Hi Josphat,
Have you installed NAV 2009 R2 or are you trying to execute it from the build only. If you are trying to execute just from the build then
I will suggest to install it first then execute the form transformation process. I too have faced some error similar to this a year before
and I remember it got solved once I Installed then did the transformation Process.
Blog - https://rockwithnav.wordpress.com/
