I added a range to filter records in datasource executeQuery() method, this works fine when opening form but if I set manually a filter in the grid header, the range set in ExecuteQuery() method are not applied.
I used view as my data source and also I need to give the option to filter the records.
Abhishek
Can you post your code here…,it will help to analyze if anything is incorrect.
Hi Saddaf,
Thanks for your quick reply.
Execute Query :
if(field1.valueStr())
formDataSource.query().dataSourceNo(1).addRange(fieldnum(table,fieldId)).value(SysQuery::value(field1.valueStr()));
super();
Abhishek
Hi Saddaf,
When I open the form I am getting the desired records i.e. based on the query Ranges I have set. but the problem happens when I try to filter the records in the grid.
Abhishek
can you try using datasource_ds.reread();
Hi Rohit,
I tried using it before the super() of the execute Query() method but it’s still not working. Shall I use it in some other place??
Abhishek
Hi Abhishek,
what is happening here is your original query is getting accumulated with a range everytime it is called.
There are 2 ways to overcome this.
Clear range on datasource everytime executequery is called.
Or, save your original query in some other query initially and then call that everytime to add range.
